+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Points: 819, Level: 6
    Join Date
    Mar 2009
    Posts
    Points
    819
    Level
    BER for OFDM using QPSK & Convolutional Encoding
    Hello,
    I have tried to simulate the performance of an OFDM system using QPSK a rate 1/2 convolutional code and a Viterbi decoder at the receiver. The problem I face now is after plotting the results, I come up with a funny graph that doesn't look anything like the theoretical result.
    Here's an attachment of the MATLAB image i obtained.
    Can anyone possibly tell me where I have gone wrong in this code?
    •   AltAdvertisement
  2. #2
    Advanced Member level 3
    Points: 9,408, Level: 23
    Join Date
    Oct 2008
    Sindh, Pakistan
    Posts
    895
    Points
    9,408
    Level
    23
    umm... there is no code only a graph.
    Here is what might have gone wrong.
    1) less number of samples transmitted (monte carlo requires a good number for accuracy)
    2) noise not generated properly
    Also, I don't find the graph to be funny
    •   AltAdvertisement
  3. #3
    Join Date
    Mar 2009
    Posts
    Points
    819
    Level
    Re: BER for OFDM using QPSK & Convolutional Encoding
    Thanks for your reply. I suspect my problem is with the noise generation, I have used the inbuilt matlab function to genrate awgn noise y = awgn(x,snr).
    Is there another way of generating noise apart from this?
    I can post the code if it will help.
    Thanks again
    •   AltAdvertisement
  4. #4
    Newbie level 5
    Points: 184, Level: 2
    Join Date
    Feb 2012
    Posts
    9
    Points
    184
    Level
    actually i got a model with desired graph, but the problem i av is after adding the convolutinal encoder and interleaver at the transmitting side, and viterbi decoder and deinterleave rat the receiving side, i was givin a block error, pls hw do i go by it. I can send the model to you let me know by sending me mail on omotayour06@yahoo.com.
    Also kindly help me attach your simulink model to the email too.
