+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Newbie level 6
    Points: 715, Level: 5
    Join Date
    May 2009
    India
    Posts
    13
    Points
    715
    Level
    filter for sigma delta ADC
    i am designing a sigma delta ADC. I have completed a second order modulator. My frequency range is upto 40MHz oversampling. My required resolution is 12 bits and so i oversample by 64 times in a second order sigma delta modulator
    My question is with the operation of filters... I heard that sinc3 filter and cic filters are best in doing the role of digital decimation filter. Which among the two is best for my specifications?
    Also i have a general doubt regarding the output...
    The sigma delta modulator gives a 1 bit stream output and the number of 1's will increase if there is a positive slope in the analog waveform and lot of 0's if there is a negative slope irrespective of the position(current analog signals voltage value) in the waveform.
    Norma ADC's provide bit stream that directly corresponds to the position (current analog signals voltage value) of the analog signal irrespective of the slope.
    How does the decimation filter change this slope indicating sigma delta output to that of a signed magnitude of signed complement form?
    •   AltAdvertisment
  2. #2
    Full Member level 4
    Points: 3,573, Level: 14
    Join Date
    Aug 2004
    Posts
    225
    Points
    3,573
    Level
    14
    Re: filter for sigma delta ADC
    sinc3 vs cic:
    guess it is a trade-off between complexity and performance. More complex -> better image removal and vice versa.
    slope to magnitude:
    all these filters do are just averaging. More complex filters given you average of the averages many times over. Now finding the average is just integration, if you ignore the scaling by number of samples. Thus the ADC gives you the slope (differential), you integrate and get your real value back by integration.
    - B
    1 members found this post helpful.
    •   AltAdvertisment
  3. #3
    Super Moderator
    Points: 254,930, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    44,424
    Points
    254,930
    Level
    100
    sinc and cic are synonymous, an n-stage cic filter has sinc raised n frequency characteristic. They are not necessarily the best,
    but the most simple decimation filters, because they don't need multipliers. They are are good suited for applications that don't
    need a steep cut-off characteristic. Giving resolution and OSR is not actually a specification in my opinion.
    2 members found this post helpful.
    •   AltAdvertisment
  4. #4
    Newbie level 6
    Join Date
    May 2009
    India
    Posts
    13
    Points
    715
    Level
    ok i get that integration part... but will its ouptut be in signed magnitude or signed complement form
    thanks for clearing the doubt over cic and sinc filters
