how to handle bias ground and RF ground of PA?
zhangm79
Member level 1
hello. one question about how to handle the bias dc ground and RF ground? They use the same ground or seperate them & connect at one point?
Thanks.
Generally there is no need to split the ground for DC bias and RF. In most cases, a single solid ground plane is the best choice because it keeps ground potential lower between every ground point and helps reduce noise and EMI, and get no IM degradation.
