RANDOM SEQUENCE GENERATOR
embeddedlover
Full Member level 5
#include<stdio.h>
#include<stdlib.h>
main()
int x = rand() % 25;
printf("%d",x);
I am using rand() function and it always gives me a output of 16.
Please give me the reason.
As per my knowledge a rand() generates random number based on system clock. But if i load to micro controller on what basis is it generating a random number?
Well.
In one of my application which use avr-libc, there is also have this problem. Every first time, rand() will generate the same value. But next, the value is different.
And I see the code:
static unsigned long next = 1;
ATTRIBUTE_CLIB_SECTION
int
rand(void)
return do_rand(&next);
static int
do_rand(unsigned long *ctx)
#ifdef USE_WEAK_SEEDING
* Historic implementation compatibility.
* The random sequences do not vary much with the seed,
* even with overflowing.
return ((*ctx = *ctx * 1103515245L + 12345L) %
((unsigned long)RAND_MAX + 1));
#else /* !USE_WEAK_SEEDING */
* Compute x = (7^5 * x) mod (2^31 - 1)
* wihout overflowing 31 bits:
* (2^31 - 1) = 127773 * (7^5) + 2836
* From "Random number generators: good ones are hard to find",
* Park and Miller, Communications of the ACM, vol. 31, no. 10,
* October 1988, p. 1195.
long hi, lo, x;
x = *ctx;
/* Can't be initialized with 0, so use another value. */
if (x == 0)
x = 123459876L;
hi = x / 127773L;
lo = x % 127773L;
x = 16807L * lo - 2836L * hi;
if (x < 0)
x += 0x7fffffffL;
return ((*ctx = x) % ((unsigned long)RAND_MAX + 1));
#endif /* !USE_WEAK_SEEDING */
Then you see, every first time, rand() initialize value is 1. So you can't get different value in first time.
I think you maybe do this to improve it:
1.Write rand by yourselft. Haha, this may be difficult.
2.Drop fist several value of rand(). The several number is must different every time.
does rand() work for micro controllers or not?
