0x9Design
Newbie level 1
- Joined
- Jan 14, 2010
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- New York, NY
- Activity points
- 1,292
I need a schematic and surface-mount PCB designed that will use a PIC18F66J60. The finished design will probably be less than ninety pins/contacts. It's a pretty simple device, but quality matters. It will be used in automotive conditions. The design should be heavily biased toward a low component count, even at the expense of increasing the component cost by a few dollars.
A designer in the US or Canada is preferred for legal reasons, and it will be done as a "work made for hire".
If you have experience with designs using Ethernet and enjoy doing quality work, then please contact me. Enclose a sample of your work or a copy of your resume w/references.
Cheers,
Peter
Cheers,
Peter
