+ Post New Thread
Results 1 to 2 of 2
10th January 2010, 05:26 #1
Noise Power of a 3rd Order digital modulator
I've done the correlation of the noise power of a 3rd order modulator. Its block diagram is shown below.
I've two results to be compared:
1. Using closed-form formula and do integration.
2. Using verilog-HDL model and post process data in matlab to obtain the noise power.
The results are respectively 0.47 and 0.5037.
I would like to learn that if this is a reasonable close correlation, or they should be exactly the same?
regards,
Neo
Advertisment
10th January 2010, 20:06 #2
I also did some homework about 1st order modulator. The calculated total output noise power is 2/3 (delta=2). The simulated with verilog model is close to 0.77.
Again, the simulated is more than calculated. Any suggestion?
+ Post New Thread
Please login
