Master's thesis topic in op amp design
sjamil02
Member level 4
United Kingdom
Hi All,
I am currently still determining the topic my for master's thesis. It has to be an op amp design project that employs gm/id and inversion coefficient (IC) sizing methodology and it has to be novel idea.
Really appreciate suggestions.
Thanks in advanced.
sjamil02
sjamil02 said:
... an op amp design project that employs gm/id and inversion coefficient (IC) sizing methodology and it has to be novel idea.
What about using a (rather) new opAmp topology like, e.g., the paper below, and develop an appropriate IC sizing methodology "construction kit", which is able to size all the topology's transistors according to the required performance parameters like gain, GBW, phase margin, output drive capability, power consumption, noise, ... ?
Don't know if this is "novel" enough for your standards, and if such a tool doesn't already exist, e.g. **broken link removed** or the **broken link removed**.
    sjamil02
erikl,
Thanks for the paper and suggestion. It helps a lot.
i just pressed helped me button :)
cheers
sjamil02
Thanks a lot, sjamil! Would be nice if it really helps you. Good luck! erikl
