Variable frequency Sine Wave generation using DSPIC
sonenarayanan
Newbie level 2
carbondale
I need to generate a sine wave whose frequency can be controlled from say, 1hz to 20Khz (Analog output of DSPIC) corresponding to 0-10V, Analog input. and also wanted to know if ampiltude control is possible similarly. Detail Circuit dwg and source code required.
Hi sonenarayanan,
I don't know how to do this using DSPIC. But can help if you prefer doing this using a DDS (Direct Digital Synthesis) chip. Checkout some DDS chips from Analog Devices. They can be very easily interfaced to a controller and the frequency is crystal controlled.
