this signal is connected to multiple drivers
eng.geobar
Newbie level 5
Syria
this signal is connected to multiple drivers.
I always get this message when I use a signal in to places in the process() , or in and out the process, or in the left or right of <=
How can I solve this problem?
To address this 'problem' you should use some intermediate signals (unique for each process) and then combine them.
Example: two processes driving the same signal:
process(...)
begin
  signalout <= ...
end process
process(...)
begin
  signalout <= ...
end process
gives you this error.
Use the following instead:
signal signalout1: ..
signal signalout2: ..
process(...)
begin
  signalout1 <= ...
end process
process(...)
begin
  signalout2 <= ...
end process
signalout <= signalout1 or signalout2;     -- Use some selection (like 'or' 'and' 'select' 'if') to combine the individual process signals
For processes you could also combine the two processes into a single process, but this is not advised.
    eng.geobar
