+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Member level 4
    Points: 1,115, Level: 7
    Join Date
    Apr 2009
    Posts
    69
    Points
    1,115
    Level
    7
    pi model
    hi all,
    I need to calculate a 2-pi model lumped circuit for an onchip capacitor and onchip transformer.
    Could you tell me a tutorial for 2-pi circuit or tell me a book to read ?
    thanks so much.
    •   AltAdvertisment
  2. #2
    Advanced Member level 3
    Points: 10,596, Level: 24
    Join Date
    Aug 2005
    INDIA
    Posts
    810
    Points
    10,596
    Level
    24
    two-port circuit
    Hello,
    You can generate a PI Model/equivalent circuit using Sonnet em Broadband spice extract from S parameters or EM structure...
    Description:
    In general, the model contains an inductor (in series with
    a resistor if using loss), a capacitor and a resistor (when using loss) connected in
    parallel from each port to ground. A similar parallel RLC network is also
    connected between each port. Therefore, a four-port circuit can contain more
    elements than a two-port circuit. Each inductor may also have a mutual inductance
    to any other inductor in the network. The figure below shows the most complex
    equivalent circuit possible for a two-port (mutual inductances not shown).
    They have free version which you can download & try
    http://www.sonnetsoftware.com/products/lite/
    ---manju---
    1 members found this post helpful.
