umery2k75
Advanced Member level 1
clamp meter
This is the electrical over head crain, it is at floor but it will go up at the column around 35ft high above the ground, you can see the relay logic diagram of the system in the picture.I was astonished to see that the electrician had used the 4 core cable in which two wires were used for input and other two for output.It's bad practice, I believe. I was busy for almost a month and unfortunately I couldn't used the internet and I was missing EDABoard alot especially postings of Fvm and topics of discussion going on, this sunday I will read all the previous postings from the last month.
