+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Newbie level 1
    Points: 618, Level: 5
    Join Date
    Jul 2009
    Posts
    Points
    618
    Level
    smd transistor markings
    What is smd top marking M6G (transistor)
    •   AltAdvertisement
  2. #2
    Newbie level 6
    Points: 799, Level: 6
    Join Date
    Jul 2009
    Antwerp, Belgium
    Posts
    12
    Points
    799
    Level
    what is smd
    Possibly MUN5130?? -that should have marking 6G, but maybe the M indicates the manufacturer....
    Check the data at alldatsheet.com to see if it would fit the rest of the circuit.
    •   AltAdvertisement
  3. #3
    Banned
    Points: 993, Level: 7
    Join Date
    Jun 2008
    Posts
    24
    Points
    993
    Level
    7
    Re: Need Help......What is smd top marking M6G (transistor)
    what package?how many pins?
    •   AltAdvertisement
  4. #4
    Banned
    Join Date
    Jun 2008
    Posts
    24
    Points
    993
    Level
    7
    Check markingcodes' original type no is our major job.Welcome to join our gold member.
    The markingcode promblem you post, i checked them for you.see below:
    M6 BSR58LT1G SOT23 Transistor-Small Signal JFET T ... ON/
    David
    david@smdok.com
    http://www.smdok.com
    we offer check-markingcode,PCB-COPY,Chip-decryption service
    We providing searching service of smdcodes(also known as markingcode,top mark,marking and package marking). Our database incluses the codes of transistors, diodes, tvs, thyristors, ics, etc. You will be suprised to find many dip components' code and many smd codes those hard to find in the internet or anywhere else. The news is that the database quantity is grouping up day by day. Nomatter easy code or difficulty code, all you need to do is to input codes and search, instead of collecting everyday. Why? Because we, your support team is doing that for you.
