pranam77
Advanced Member level 5
One of my friend gave me an emergency light with 11 watt CFL (AS shown in the photo) which operates with an Push pull inverter circuit powered with 6 volt 10 Ah battery. It has a peculiar problem which he coudnt solve. Initially the tube was blackened, and i replaced it. Within 10 minutes i lost the tube due to blackening at the ends. I tried with new tube of another make but with the same result.
Thus my questions are
1. What factors result in blackening of the Tubes?
2. Can rewinding the Ferrite transformer will help?
3. Should i measure the inductance of all the coils and wind with the same details?
4. Is the choke in series to the Positive supply reponsible for blackening?
5. Is the gaps between the 2 EE cores critical?
6. What factors are determined by the core gaps?
6. How can the distance between the cores determined?
Thanks in Advance
Pranam77
Thanks in Advance
Pranam77
