+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Advanced Member level 2
    Points: 5,456, Level: 17
    Join Date
    Nov 2005
    Posts
    503
    Points
    5,456
    Level
    17
    How to convert std_logic_vector to hexadecimal
    How to convert std_logic_vector to hexadecimal ?
    Thanks.
    •   AltAdvertisement
  2. #2
    Points: 10,814, Level: 24
    omara007's Avatar
    Join Date
    Jan 2003
    Cairo/Egypt
    Posts
    1,238
    Points
    10,814
    Level
    24
    Hexadecimal is not a type like std_logic_vector. Hexadecimal is a representation. So, you can always represent the std_logic_vector signal in terms of Hex format.
    What do you want to do exactly ?
    •   AltAdvertisement
  3. #3
    Join Date
    Nov 2005
    Posts
    503
    Points
    5,456
    Level
    17
    Re: How to convert std_logic_vector to hexadecimal
    I want to convert std_logic_vector to character.
    Should I convert std_logic_vector to hexadecimal first?
    the following is my code:
    procedure hex2chr( variable hex  : in std_logic_vector( 3 downto 0);
                        variable char : out character) is
    	 begin
    		 case hex is
    			 when "0000" =>    char:='0';
              when "0001" =>    char:='1';
              when "0010" =>    char:='2';
              when "0011" =>    char:='3';
              when "0100" =>    char:='4';
              when "0101" =>    char:='5';
              when "0110" =>    char:='6';
              when "0111" =>    char:='7';
              when "1000" =>    char:='8';
              when "1001" =>    char:='9';
              when "1010" =>    char:='a';
              when "1011" =>    char:='b';
              when "1100" =>    char:='c';
              when "1101" =>    char:='d';
              when "1110" =>    char:='e';
              when "1111" =>    char:='f';
              when others =>
               ASSERT (false) REPORT "no hex character read" SEVERITY failure;
             end case;
    end hex2chr;
    Thanks.
    •   AltAdvertisement
  4. #4
    Super Moderator
    Points: 260,240, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    45,443
    Points
    260,240
    Level
    100
    character is a VHDL standard type, but it has no particular purpose in synthesis, it's mainly used in text_io for simulation purposes. So what do you want to do with the char output of the procedure?
  5. #5
    Join Date
    Nov 2005
    Posts
    503
    Points
    5,456
    Level
    17
    I am doing a closed loop simulation.
    I want to record the feed-back std_logic_vector.
    Thanks.
  6. #6
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    45,443
    Points
    260,240
    Level
    100
    So you want to perform hexadecimal textio output. This should work.
    1 members found this post helpful.
    •   AltAdvertisement
  7. #7
    Join Date
    Nov 2005
    Posts
    503
    Points
    5,456
    Level
    17
    are you sure?
    looks like it has erros, keep showing "ASSERT (false) REPORT "no hex character read" SEVERITY failure;"
    why?
  8. #8
    Advanced Member level 3
    Points: 9,432, Level: 23
    Join Date
    Jul 2004
    Posts
    892
    Points
    9,432
    Level
    23
    Check out this one!
    function to_hstring (value     : STD_ULOGIC_VECTOR) return STRING is
        constant ne     : INTEGER := (value'length+3)/4;
        variable pad    : STD_ULOGIC_VECTOR(0 to (ne*4 - value'length) - 1);
        variable ivalue : STD_ULOGIC_VECTOR(0 to ne*4 - 1);
        variable result : STRING(1 to ne);
        variable quad   : STD_ULOGIC_VECTOR(0 to 3);
      begin
        if value'length < 1 then
          return NUS;
        else
          if value (value'left) = 'Z' then
            pad := (others => 'Z');
          else
            pad := (others => '0');
          end if;
          ivalue := pad & value;
          for i in 0 to ne-1 loop
            quad := To_X01Z(ivalue(4*i to 4*i+3));
            case quad is
              when x"0"   => result(i+1) := '0';
              when x"1"   => result(i+1) := '1';
              when x"2"   => result(i+1) := '2';
              when x"3"   => result(i+1) := '3';
              when x"4"   => result(i+1) := '4';
              when x"5"   => result(i+1) := '5';
              when x"6"   => result(i+1) := '6';
              when x"7"   => result(i+1) := '7';
              when x"8"   => result(i+1) := '8';
              when x"9"   => result(i+1) := '9';
              when x"A"   => result(i+1) := 'A';
              when x"B"   => result(i+1) := 'B';
              when x"C"   => result(i+1) := 'C';
              when x"D"   => result(i+1) := 'D';
              when x"E"   => result(i+1) := 'E';
              when x"F"   => result(i+1) := 'F';
              when "ZZZZ" => result(i+1) := 'Z';
              when others => result(i+1) := 'X';
            end case;
          end loop;
          return result;
        end if;
      end function to_hstring;
    Hope this helps!
