Power-on Reset pulse generator
always@smart
Full Member level 4
ASIA
site:www.edaboard.com por circuit
DOes anyone have done this design before, please share any circuit or any documents.
THank you
Regards,
always@smart
Re: Power-on Reset Circuit
Hi
Have a look here :
h**p://www.maxim-ic.com/products/supervisors/simple_resets.cfm
h**p://www.maxim-ic.com/products/supervisors/regulators.cfm
h**p://www.maxim-ic.com/appnotes.cfm/appnote_number/1186/ln/en
h**p://cache.national.com/ds/LP/LP3470.pdf
h**p://www.sigcon.com/Pubs%5Cedn%5Cpor.htm
h**p://www.micrel.com/_PDF/mic705.pdf
* = t
See this file .
I usually don't use POR, because it is a problem for the test of digital circuit. You need to be able to synchronise your data with the tester.
OkGuy
Hi all,
I need the power on reset circuit, not the application notes or the block diagrams.
Thanks in advance
always@smart
A circuit can be a very low current source, a capacitor and a shmitt trigger. After reset, turn of the current source and lock your state.
Hello always@smart!
You can try the TI voltage supervisor's, this is a small CI with many features...check the TI site!
Gorkin
Using the IC KIA72xx,XX is Reset Signal Generation Starting Voltages.
You can search it(such as KIA 7229) in Google.
ynhe
I kow a por circuit always includes a smt circuit and a charge cap basicly
