cachep
Member level 2
illegal rate transition found
I am run a sample in Simulink. However, some errors occur as following:
"Illegal rate transition found. Sample time [0 1] of 'hamming1/Time Scope' at input port 1 is different from sample time [0.5714285714285714 0] of its source 'hamming1/Unbuffer' at output port 1. A Rate Transition must be inserted between them"
Please help me to solve this problem. Thank you very much!
