simple preemptive round robin scheduler for AVR?
7rots51
round robin preemptive
Is there any code for simple preemptive round robin scheduler for AVR?
(not freertos or ucos-II)
sample program in round robin scheduling
Its easy to make using a timer and a small logic for swapping between the processes
you will be using different stacks for different processes
and a default for startup
i have made a roundrobin scheduling program for atmega128 which switches between the processes at the timer interrupt
avr round robin
Thanks for your help,Please send your code for Mega128 ,I want to look at it and get some idea.It may help me.
avr scheduler
Hello.
You can use Freertos. Its supports several micros.
you can see the examples of task scheduling
https://www.freertos.org/
I worked alot with Cortex M3 using raid Ide
Regards
avr+simple+scheduler
free RTOS is too heavy for AVR and my needs ,I need only a small part of it.
I work with IAR AVR C compiler,how to store task stack?IAR have 2 stack . How save them?
