How to see the values of the variable counter using Proteus?
muganga
Newbie level 6
I trying simulate the following code. I did not find option: PIC CPU SOURCE CODE...just REGISTERS, DATAMEMORY, PROGRAM MEMORY AND STACK.
I want assist what values the variable counter get during running the program.
Is it possible use proteus??
#include <16C77.h>
#use delay(clock=4000000)
#include <lcd.c>
#int_TIMER0
void TIMER0()
int counter;
set_timer0(0);
if(counter == 15)
counter++;
void main() {
setup_timer_0(RTCC_INTERNAL| RTCC_DIV_256|RTCC_8_BIT); //clock interno; prescaler; 8bits
enable_interrupts(INT_RTCC);
enable_interrupts(GLOBAL);
lcd_init();
lcd_gotoxy(1,1);
lcd_putc("teste");
tks
fernando
setup_timer_0(rtcc_internal|rtcc_div_256);
Yes it is possible in Proteous
instead of loading *.HEX Load *.COF file onto your chip
this will show your source code and Variables too
Remember if your variable is global then it sustain a permanent value Locals are created and destroyed
timely.
setup_timer_0(rtcc_internal|rtcc_div_1);
thank you very much for information...
I did what you sugest but I could not see the variable counter..
do you know why?
#include <16C77.h>
#include <lcd.c>
#int_TIMER0
void TIMER0()
int counter;
set_timer0(0);
if(counter == 15)
counter++;
void main() {
lcd_init();
lcd_gotoxy(1,1);
delay_ms(100000);
lcd_putc("Welcome to EGYPT");
thanks again
muganga
proteus step
Proteus is just a waste of time.....
proteus step by step
Thank you for reply..so..what is the best software to simulate a circuit?
tks
muganga
proteus +step
where is your init timer code?
also why you do this
if(counter == 15)
counter++;
do you want to do it like this
if(counter == 15)
counter = 0;
hock
Re: proteus step by step
clock = 4Mhz
4/4*256*256 = 0,065536 s
15*0,065536 = 1seg
if I have an overflow 15 times that means I have 1 seg. In this way I can count 1 seg and I want display on lcd.
tks
muganga
but your code is wrong.
it will never increment the counter as in the begining count = 0 and hence the condition IF count == 15 will never be true ans count ++ will never work. the count will remain 0x00.
hock
I change the code and know it is working..
for someone who are learning interruption..see below the code...
#include <16C77.h>
#include <lcd.c>
int counter;
int seg=0;
int value;
#int_TIMER0
void TIMER0()
counter++;
if(counter == 15)
counter=0;
seg++;
void main() {
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256|RTCC_8_BIT);
while (1)
lcd_init();
lcd_gotoxy(1,0);
printf(lcd_putc,"\f tempo : %i segundos",seg);
delay_ms(200);
