Results 1 to 4 of 4
    Junior Member level 3
    Points: 1,741, Level: 9
    Dec 2003
    26
    1,741
    9
    envelope detectors
    I'd like to extract a QAM signal's amplitude and phase from its IF (@40MHz) signal.
    I figure an envelope and phase detector will do the job, however I'd like some more information on the design issues entailed. Can anyone point me to a paper or book that describes these in some detail?
    Also is there another way to get amplitude&phase?
    Points: 36,491, Level: 46
    flatulent's Avatar
    Jul 2002
    Middle Earth
    4,629
    36,491
    46
    Re: Phase detectors and envelope detectors
    You will need a local phase reference to do the angels. QAM is expensive enough to do that you should not economize on the detector method. Using the I and Q coherent detectors and level slicers should be done.
    If you are making a low cost system, OOK or FSK would be cheaper.
    Junior Member level 1
    Points: 1,730, Level: 9
    Sep 2003
    19
    1,730
    9
    I point you to chapter 8 of Digital Modulation Techniques book.
    Link to the book
    http://www.elektroda.pl/eboard/searc...tml+techniques
    Dec 2003
    26
    1,741
    9
    Thanks for your replies. Sorry I wasn't quite specific.
    The QAM modulation (and demodulation) is done digitally and afterwards that I/Q is combined digitally, oversampled and then converted to analog at an IF freq of let's say 30MHz using eg @D9856.
    (Taken from @D: The @D9856 integrates a high-speed direct-digital synthesizer (DDS), a high-performance, high-speed 12-bit Digital-to-Analog converter (DAC), clock multiplier circuitry, digital filters, and other DSP functions onto a single chip, to form a complete quadrature digital upconverter device. The @D9856 is primarily intended to function as a universal upstream and downstream I/Q modulator for interactive HFC cable network applications, where cost, size, power dissipation, and dynamic performance are critical attributes.)
    What I want to do is design a predistortion circuit in the Tx path right after the low pass filtering of the Tx DAC and for this I need amplitude and phase info which is not available from the baseband modem.
