Hi, Blackuni
Thank you for your reply, but I am sorry I can not attach the netlist here.
The resistor subcircuit can be recognized by changing the XX to rx, for example:
XXI18/RR0__1 N_MR_XI18/RR0__1_pos X290/noxref_5 rpo1 109.957 w=4.5e-06 l=6e-05
to
rXI18/RR0__1 N_MR_XI18/RR0__1_pos X290/noxref_5 rpo1 109.957 w=4.5e-06 l=6e-05
The netlist check has passed, but when simulating, another error has come:
when I use the netlist generated by Calibre PEX, it will show that:
hspice diagnostic for nonconvergent nodes and elements
node subcircuit old new error
name definition voltage voltage tolerance
(x1.net30#18) design 4.72e+00 4.71e+00 1.60e+00
(x1.mi6/m17:id) design 2.41e-03 2.46e-03 1.01e+00
(x1.mi6/m39:id) design 1.86e-01 1.86e-01 2.93e+00
total voltage source power dissipation= 7.129e-02 watts
**** bipolar junction transistors
**** mosfets
***** job aborted
and the simulation will be aborted....
What is the matter with it?
