divit
Newbie level 6
I need to generate pwn signals at port 0.0-0.7 and port 2.0-2.7.The pwm signals should change their Ton period according to digital value received from the adc by each sensor.every pin will hav a different pwn signal according to correspoding value of the sensor.the sensor will basically be a 5k ohm pot .the pwm signals will run a servo motor.the servo motor should move between 0 to 90 degrees.I am also posting the schematic please help me out i need to do this for my final year project
