Can I use a bias tee in a reverse way? This device is usually employed to add a DC bias to an AC signal, but suppose that I have an AC signal with a DC level...Can I put this into the output of the bias tee and separate the AC and DC components?
Yes it should work backwards (sort of) it will be like spliiting a DC line you will receive DC power on both lines. but you will be able to tap into the DC power with out disturbing the AC line in this method.
The only way to rid the line of the DC power is to us a capacitor.
One problem you might run into is if the signal has a lot of bursty information on it. The ac coupled output signal may move up and down in DC level (i.e. not stay at zero volts dc) in the short term.
No that is not correct it will never be at zero volts.
It will always be at the voltage that is on the line that you are trying to pick off.
Here is an example, Put +5 volts on a wire, now split that wire into two wires and on one wire put a LED (something to draw power) now measure the other line there will still be 5 volts on that line.
in this case the LED will is where the DC bias is taken off the line (usually with an fan out) and the AC line is the line you measure.
The AC line will have +5 volts on and so will the DC bias line.
The only way to make this work with having only AC on one line and only DC on the other is to put a DC block (a capacitor) on the AC line right after the DC bias tap (usually a fan out)
