Check how many input bits will you be feeding the DAC. Most common are the 4 bit and 8 bit DACs. Higher ones are also available. You can also use a R-2R ladder circuit instead of DAC. Check coughlin's op-amp book for reference.
For ADCs, it's the oppostie. You need to know how many output bits you require. For most cases 8 bit ADC is more than enough unless you require really high resolution.
rectifier,
For both DAcs and ADCs you need to determine the minimum number of bits required. Let
. Vmax = Maximum output(ADC) or Input(DAC) range
. Vres = minimum voltage change the you need
. to detect(ADC) or output(DAC)
. Nmin = minimum number of bits
Then Nmin = log(base2) of Vmax/Vres.
This is for the ideal case. For real world cases with noise, you need to determine Effective Number of Bits (ENOB). for a basic ENOB disussion, see the article "ADCs: Does ENOB tell the whole story?" from the 4/17/2008 of EDN magazine. www.edn.com/article/CA6549029.html?text=Does+ENOB+tell+the+whole+story? -
You also must consider speed. For ADCs this is determined by the conversion time, which is given on the data sheet. For DACs this is determined by the settling time and, for serial DACs, the input clock speed and data protocol.
Regards,
Kral
