How can a if else statement imply priority whereas the case statement do not?
ASIC_intl
Banned
priority in HDL
This would help -
priority in HDL
The conditions in an if ... elsif ... else ... end if chain are not necessarily mutual exclusive, but the choices of a case construct are.
Re: priority in HDL
Fvm
What do u mean by Mutually exclusiveness here?
Added after 9 minutes:
HI tut
Can u give me some sides of Xilinx which writes dood documents of digital design and verification
Re: priority in HDL
in fact, you should avoid these kind of circuits!
Re: priority in HDL
Very simple, in a case construct only one choice can be valid at a time, no choice is allowed to include a value or a range of another. Thus the order of evaluation doesn't matter and no choice can be priorized over another.
priority in HDL
Hi ASIC_intl,
The best is you write the code using case statement and if..else statement. Then, use a synthesis tool to synthesize both the codes.
Now, you can see the different between these 2 codes.
As for the synthesis tool, you can use xilinx ISE or quartusII. Else, if you have the luxury to use more powerful tool such Design Compiler or Leonardo Spectrum or etc., then please use it and do comparison.
All the best! :)
Re: priority in HDL
HI tut
You can search Xilinx's site. Its a Knowledge mine. :D
