+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Member level 5
    Points: 1,677, Level: 9
    Join Date
    Jun 2006
    Posts
    84
    Points
    1,677
    Level
    9
    when the op unstable , what is its behavior?
    When OP is unstable ,and it connects as closeloop , what is its output and freq , or its relationship ? if the output is not VDD or GND , just like the osc application
    •   AltAdvertisement
  2. #2
    Advanced Member level 5
    Points: 40,458, Level: 49
    Achievements:
    7 years registered
    LvW's Avatar
    Join Date
    May 2008
    Germany
    Posts
    5,790
    Points
    40,458
    Level
    49
    Re: when the op unstable , what is its behavior?
    When the opamp with feedback does not function as a stable amplifier - and when at the same time its output is neither at Vdd nor at Vcc (or ground in case of single supply) it probably will oscillate at a frequency fo. This frequency fo can be found in the BODE plot of the loop gain where the magnitude is 0 dB.
    •   AltAdvertisement
  3. #3
    Newbie level 6
    Points: 877, Level: 6
    Join Date
    Jul 2008
    Posts
    12
    Points
    877
    Level
    natch, as LvW says, the criteria for oscillation are:
    1. Gain greater than 1 at frequency f0
    2. positive feedback (i.e. 360 degree phase shift from input to output at frequency f0)
    congratulations! You arent stable! I think its called the Barkhausen criteria.
    again, as LvW points out, these can be taken from a properly constructed Bode plot (or more accurately stated, a properly loaded circuit)
