+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Full Member level 4
    Points: 3,740, Level: 14
    Al Farouk's Avatar
    Join Date
    Jan 2003
    Egypt
    Posts
    191
    Points
    3,740
    Level
    14
    Orc@d Problem
    I use Orc@ad 9.0, I draw a small circuit at Capture CIS capture schematic targeting PCB design, the problem contain 1 IC, one relay and some passive component the problem is that when I generated the nellist and BOM the relay dos not appear in the BOM or as a component when I go to the layout although ne error appear while generating the BOM or while importing the design to layout. I wander why this specific component did not appear although the flyweel diod conneted to it and all other component appear in layoput.
    dos any one face this problem before ?
    •   AltAdvertisement
  2. #2
    Full Member level 4
    Al Farouk's Avatar
    Join Date
    Jan 2003
    Egypt
    Posts
    191
    Points
    3,740
    Level
    14
    Re: Orc@d Problem
    I creat a new symoble replacing the ready supplied one the problem solved by this way.
