+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Junior Member level 3
    Points: 2,153, Level: 10
    Join Date
    Jan 2003
    Posts
    27
    Points
    2,153
    Level
    10
    Dividing junction capacitance of photodiode to smaller piece
    I am trying to compare is it possible to get better results ( noise, BW...) dividing large junction capacitance of photodiode to smaller sections.
    I attached an example picture, which shows the idea.
    As you can see ( picture ) there has used separate TIAs for all of the smaller photodiodes. I think to reduce power dissipation there could be better ways of doing that " current summation " ( for example using basic common gate transistors for separate diodes and then one TIA...)
    Does anybody have any other options/ideas how to make that photocurrent summation from invidual photodiodes?
    •   AltAdvertisement
  2. #2
    Advanced Member level 1
    Points: 5,679, Level: 17
    Achievements:
    7 years registered
    Old Nick's Avatar
    Join Date
    Sep 2007
    Posts
    480
    Points
    5,679
    Level
    17
    Re: Dividing junction capacitance of photodiode to smaller p
    I can't really see what you're trying to do.
    I don't think you'll get better noise performance by adding more amplifiers.
    Also, is there a reset switch going from Vdd to the photodiode tho charge it up? Or do you have it in a logarithmic configuration?
    A log pixel will give you a higher bandwidth! (you just have to live with the log response.)
    •   AltAdvertisement
  3. #3
    Advanced Member level 2
    Points: 5,019, Level: 16
    Join Date
    Sep 2004
    Posts
    511
    Points
    5,019
    Level
    16
    I am not sure that this is an good idea. Of course depends on system characteristics.
    Seperated capacitance is not equal to C/4, because of edge capacitance.
    Note that if noise at the amplifier output is decreased by factor 4 you had nothing improoved, because signal is also decreased by factor 4.
    If you decrease Cf, you could have problem with stability, but that depends on your amplifier speed. You will probably need Cf in parallel with Rf.
    •   AltAdvertisement
  4. #4
    Super Moderator
    Points: 260,203, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    45,439
    Points
    260,203
    Level
    100
    It's a matter of noise matching to my opinion. If you are required to use an existing TIA, that has optimal noise performance with smaller photodiodes, paralleling amplifiers can be expected to give an inprovement. If the TIA noise parameters are known, the noise behaviour can be estimated rather precisely.
  5. #5
    Points: 10,068, Level: 24
    leo_o2's Avatar
    Join Date
    Sep 2004
    China
    Posts
    1,324
    Points
    10,068
    Level
    24
    In my opinion, separated TIAs will lead to worse noise characteristic.
    •   AltAdvertisement
  6. #6
    Join Date
    Jan 2003
    Posts
    27
    Points
    2,153
    Level
    10
    I am trying to find some other way to join photocurrent from separated diodes ( something else than using parallel TIA:s ) Maybe like in picture which i attached or some kind of other current sum-structure ( ideas? )
