Requirement for bandgap bandwidth
niklas.zhu
Newbie level 6
From my point of view, there is no special requirement on bandwidth of bandgap,
and it only used when calculating integrated noise.
Am I understanding right?
thanks,
Re: bandgap bandwidth
Could anyone help me?
bandgap bandwidth
i think low bandwidth also have low psrr bandwidth.
bandgap bandwidth
the bandgap bandwidth means the effect the filter the noise which from the vdd and the substract.
so if there are low bandwidth ,there should be a good psrr .and a high bandwidth should get the poor psrr
Why not do a simulation for psrr and cross check?
Added after 52 minutes:
A lower bandwidth will lead to a poor psrr on higher frequencies... as the gain rolls off at low frequencies...
also a low (loop)bandwidth leads to slower transient responses... higher startup and settling times...
hope this helps.
