Methods for PCB fabrication without acid
Bukitoo
Full Member level 2
Argentina
Hi !!!
I want to know the techniques for doing PCB without acid.
I know that there are numerical controlled machines that do that, but I dont know their names.
Does exist another method ?
THanks
pcb fab machine
hello dear
this is your missunderstandig that pcb can be made without acid ok?
CNC machines only do drilling or cutting of PCBs.
you can not atch the PCB without any chamical .Yes u can use "Faric Chloride" instead of any hamfull acid.
this chemical is used usually.
for more, mail me
noman
pcb fabrication machines
The Quick Circuit System from t-tech produces accurate, economical, and quick circuit board prototypes directly from your current CAD package's data. The Quick Circuit accepts Gerber, DXF, HPGL & Excellon files. No acid or harmful chemical involves. See www.t-tech.com It costs $14,995~ $20,995 depending on options
build your own pcb cnc
there's a CNC machine named LPKF
that do the PCB without any chmicals
homemade pcb cnc
LPKF is the best and the more accurity machine to get fast a PCB prototype !!!
pcb fabrication at home
The machines used only for this purpose are expensive. I am using a desktop CNC mill ($2500) to do the job. It requires a bit of tweaking. More daring enthusiasts can rig-up their own routers for less than a thousand bucks. Its not that difficult. Search google for PCB router and you will find a design that can be made for under a thousand dollars.
pcb panel size
MicroKinetics (around $10K) and Data Design Instruments (around $8K)have cheaper PCB CNC machines than LPFK.
h$$p://www.microkinetics.com/pcbproto.htm
h$$p://ddi.isrv.com/ddiprod.htm
This guy sells plans if you want to build your own.
h$$p://www.crankorgan.com/index.html
homemade pcb routers
Using the chemicals is the best thing because it saves a lot of time compared to the time taken by the PCB prototyping machine. Also the runing cost of the PCB prototyping machine is very high because the used tools cost is very high. For single side PCB i recommand to use chemicals for double side you will need some time to get a better quality PCB with the chemicals.
cost for color pcbs
The PCB making can be acheive using prototype PCB making (milling machine).
It will cut the copper layer on the PCB forming traces,
instead of using chemical to remove the copper.
homemade pcb colour how to
We are manufacture low cost, high quality PCB prototypes in China.
we also supply RoHS Compliance,Leed Freed PCB prototype.
Silk masks are produced for the same price
Send us a PCB file and we will reply promptly with a quote.
We can assemble components for your company.
if any question, Please email us with your questions.
We sell high quality HDI PCB's.
accept delivery times are prompt.(quick turn)
We can supply color PCBs board(Example: Blue, Black,Red,Green,White,yellow.)
Mail: njpcb@vip.163.com or sales@njpcb.com
E-mail pcb files to us and we will provide a prompt quote.
We sebd PCB via DHL or UPS ( Approx 1 day from Chins to the USA)
Product Name: Printed Circuit BoardPlace of Origin: ChinaFeatures:
1) Surface finish: hot air solder leveling, entice, immersion gold,
carbon ink, gold finger, peelable mask
2) PCB file format: protel,powerpcb,Gerber file,Engle....
3) Profile: routing, punching, V-Cut, chamfered
4) Number of layers for mass production: 2 – 12
5) Finished copper weight from .25 to 3oz
6) Minimum finished hole size .006"
7) Min. trace .004" - Min. space .004"
8) Max. panel size: 18" x 24"
9) Printed circuit board final thickness from .016" to .125"
10)soldermask /Legend in a variety of colors (Green,White,Black,Yellow,Red..)
Lead times: 2 layers( 1 days, 3 days, 5 days) Ships next day.
4 layers( 2 days, 5 days, 7 days)
6 layers( 3 days, 5 days, 8 days)
Min Qty 3pcs.
Web:www.n j p c b.c o m
mail: sales@n j p c b.c o m
Contact Person: Mr. Ding JiaBao
Website: http://www.njpcb.com
E-mail: njpcb@vip.163.com or sales@njpcb.com
Any advice will be greatly appreciated!
if any question,Please send e-mail to us,we will reply as soon
Added after 2 minutes:
Min Qty 3pcs.
Website: **broken link removed** jpcb.com
E-mail: n j pcb@vip.163.com or sales@nj p cb.com
board fabrication lead time for 6 layers pcb
the LPKF machine are used mainly for driling and the type of its routing called isolated routing cause it etchs only few mm width needed to seperate/isolate tracks from each other and leaves most of the couper layer, unlike the chemical etching that removes the layer and leaves the tracks, best way to do it by silk screen.
chemicals are better, save time and suitable for mass production..
pcb board+without acid
This is a very helpful book:
**broken link removed** 1,3MB
For home made PCB, you should use a portable drill, only think of a CNC when you are milionnaire.
nguyennam
