How to play dat, rm, mp3 files on Ubuntu and add/remove applications
QMA
Member level 4
i also want to know about how can i play dat, rm, mp3 files on ubuntu. i m not understanding how can i use add/remove applications. as i click on add/remove applications the window opens is different from the details of help instructions and images.
Ubuntu
run Synaptic and install gstreamer0.10-ffmpeg etc
Ubuntu
install win32codecs
you can also try vlc
Re: Ubuntu
Installing VLC is better. Otherwise, you can also install the KLite Mega Codec Pack for Linux. This gives you an additional player, Media Player Classic.
Re: Ubuntu
im using vlc and it is working fine
Re: Ubuntu
ubuntu is great Linux OS for me.
Re: Ubuntu
Hello,
Ubuntu is a open source operating system built around the Linux kernel.it is comprised of developers, programmers, testers, techwriters, documentation testers, translators, and most importantly, the people who use Ubuntu every day.
Re: Ubuntu
Hello,
i am indian
good for u that u r indian
Re: Ubuntu
I think you should try the VLC. This is the best software to play every type of format.
Re: Ubuntu
to install vlc u always in internet access then only it will download vlc.deb package. then also u need to open a mp3 file in default ubuntu player and then need to search plugin it will automatically installed..
Re: Ubuntu
Install mplayer. If Ubuntu doesn't have pre-packaged mplayer then get the sources. Configure using --enable-gui --yasm=''
make , and make install.
I assumed you you know what mplayer is and you have development suit installed.
Then you have to download skins for the mplayer and install it by copying it. that's it.
