Difference between linear element and non-linear element
bala9383
Member level 1
Difference between linear element and non-linear element??
Transistor is a linear or non-linear??
Transistor
transistor is a non-linear device.... it can be considered linear based on the signal and that too over a small region of operation...
Transistor
a device is said to be linear, if the input and output current follow a linear relation. i.e., any change in input produces a corresponding change in output given by the linear equation, y = mx.
non-linear device doesn't follow this relation, and the output might not change at all with an increase or decrease in the input current.
In a transistor, when this happens, we call it the saturation region.
Re: Transistor
What about capacitor and inductor are they linear elements !
Linear element is an electrical element having linear relationship between current and voltage.
Resistor is perfect example.
Transistor , Diode are Non -Linear elements.
Because they don't always follow the linear relationship between current and voltage.
Capacitor and Inductor are Linear elements.
FYI :
Linear elements :
In an electric circuit, a linear element is an electrical element with a linear relationship between current and voltage. Resistors are the most common example of a linear element; other examples include capacitors, inductors, and transformers.
Nonlinear Elements :
A nonlinear element is one which does not have a linear input/output relation. In a diode, for example, the current is a non-linear function of the voltage.Most semiconductor devices have non-linear characteristics.
Active Elements :
The elements which generates or produces electrical energy are called active elements. Some of the examples are batteries, generators,transistors,operational amplifiers,vacuum tubes etc.
Passive Elements :
All elements which consume rather than produce energy are called passive elements, like resistors,inductors and capacitors.
Source : **broken link removed**
Basically if they obey Ohm's low, they are linear.
the components which gives linear response like for increse in input; output will be more such components are linear ex-resistror, capacitor etc..and exactly reverse in case of non linear components
