atmospheric pressure sensor
m@th
Newbie level 3
I'm searching atmospheric pressure sensor to connect with my PC. I need to know what is the best sensor, datasheet & price, & circuit to connect him via parallel port or other.
thanks
Motorola have excellent devices a low cost!
check now: www.motorola.com
The typical price is: $4.60
gorkin
You can try with the Fujikura sensors with signal conditioning components on chip.
www.fujikura.com
You can use a microcontroller with a/d converter to connect the sensor to your PC by serial or parallel port
Regards
