Lattice ISPlsi software
ahf2009
Newbie level 1
lattice isplsi
Hi, I have some ispLSI1032-80LJ and the actual software and some other versions don't work with this.
Can anyone send me an older version of lattice software (like PDS or other old version)?
I have tested isplever classic, isp synario and ispexpert.
Older versions of ispsynario/ispvhdl will be very useful too.
email: ahf2009@gmail.com
Thanks so much.
lattice isplsi
Lucky you. I was able to find a floppy disk version still working...
I will email you version 2.50 with corresponding license.
TurboPC
isplsi
Hi there,
I got the same problem as you. I have several ispLSI1016 ic's, a logic analyser pcb, jedec files and a LPT JTAG downloader, but no Lattice software to program the ispLSI.
Can you help ?
email: upholm(at)yahoo.dk
Peter
isplsi pds software
That email account seems disabled or invalid. Please confirm.
hi,
it should be ok, please try again
kindly Peter
Like others in this thread, I've searched all over for this PDS development system to fix a plsi1016 and couldn't find any versions of it anywhere.
Requesting it here is my last hope...if TurboPC or someone else wouldn't mind sending it over, or point to where I can get it, I would appreciate it a lot!
email - netraider(at)mail.pt
Many thanks,
NR
Hey TurboPC!
Thank you, thank you.. thank you!
That was superfast!!
Will try it out and report later.
oh, and thank you again :)
cya
NR
Hello
I'm here for the same reason... I have a number of ispLSI's and
this is the only place I might get pDS
If somone could share with me a version or show me the way to obtain a copy?
Thanks a lot
Hi!
I have same problem :(
and need badly an old pDS Lattice software to fix ispLSI1016
some time ago I've found a russian site with two-dsik distribution
but it isn't working anymore...
please share: jack.ravenno (AT) gmail.com
Thank You very much!
[SOLVED] Thank You TurboPC for Reply and very helpful links :)
I also have the same issue. Can someone send me an old version of pDS?
Thanks in advance.
(mitchell_philip@hotmail.com)
Phil
Check your email. Enjoy!
Edit: new email sent! I forgot the patch I made for pDS v2.50
For those interested, I have pDS v2.50 and pDS v2.61 (program and patch). Thanks to toriman for supplying pDS v2.61. I even found a patch I made for v2.71 if anyone has the program.
Reactions: sxlk
    sxlk
Same problem here. I have some Isplsi1032E and I want to experiment with them.
Ill be grateful if you can send me the software too.
Thanks and Regards
Carlos
Just tell me where to email it...
Sorry TurboPC. I though that I could be reached thru the forum.
This is my email (lu2adw@yahoo.com.ar)
Thank you very much
Carlos
what software and hardware i need to program a pld ispLSI 2064ve?
You need the PDS software to design the ispLSI device. I do not remember what was used to download the code into the device. It has been more than 18 years...
I found some of these in an old box of stuff at work. Would you please send me a copy of the design software to Doug.Beck.Jr [at] gmail.com. I would like to experiment with these.
I sent it to you at the specified email address.
Reactions: skokov
    skokov
