The difference betwen trickle charger and precharger
maahtdk
Hello;
I'm new be in layout, i asked about the difference betwen trickle charger and precharger.
Thanks a lot
Re: trickle charger
Precharge : A charging method who charges a long unused or brand new battery. It normally uses a small current to charge the battery until predefined voltage level is met. It happens in the beginning of the charging process
Trickle charging : A charging method which uses to charge the battery at a low rate (C/100), balancing losses through a local action and/or periodic discharge, to maintain the battery in a fully charge condition. Thus, It happens at the end of the charging process.
For reference, you can refer to the attached.
Re: trickle charger
hi,
Does your statement applies for both Ni-Cad and Li-Ion? Please confirm
