+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Points: 899, Level: 6
    Join Date
    Feb 2008
    Posts
    7
    Points
    899
    Level
    The difference betwen trickle charger and precharger
    Hello;
    I'm new be in layout, i asked about the difference betwen trickle charger and precharger.
    Thanks a lot
    •   AltAdvertisment
  2. #2
    Junior Member level 3
    Points: 1,356, Level: 8
    Join Date
    Feb 2008
    HongKong
    Posts
    30
    Points
    1,356
    Level
    8
    Re: trickle charger
    Precharge : A charging method who charges a long unused or brand new battery. It normally uses a small current to charge the battery until predefined voltage level is met. It happens in the beginning of the charging process
    Trickle charging : A charging method which uses to charge the battery at a low rate (C/100), balancing losses through a local action and/or periodic discharge, to maintain the battery in a fully charge condition. Thus, It happens at the end of the charging process.
    For reference, you can refer to the attached.
    •   AltAdvertisment
  3. #3
    Full Member level 3
    Points: 2,238, Level: 10
    Join Date
    Dec 2007
    Chennai-India
    Posts
    169
    Points
    2,238
    Level
    10
    Re: trickle charger
    hi,
    Does your statement applies for both Ni-Cad and Li-Ion? Please confirm
    •   AltAdvertisment
  4. #4
    Join Date
    Feb 2008
    HongKong
    Posts
    30
    Points
    1,356
    Level
    8
    Re: trickle charger
    Dear Rajeshkumar,
    I am refering to Li-ion.
    For Ni-Cad,
    you can refer http://www.powerstream.com/NiCd.htm
    or patent with patent number 4806840
    or http://www.maxim-ic.com/appnotes.cfm...e_number/3999/
    Thanks
