Hspice err:internal timestep too small in transient analysis
ehsan_r34
Hspice error
Please tell me why the following error occured in Hspice?
my circuit is a switched cap circuit.
" **error**: internal timestep too small in transient analysis"
Please answer me as soon as possible.
Thanx
Added after 2 hours 19 minutes:
Can i increase the resolution of the analysis of Hspice?
Hspice error
it's the convergence problem.
i suggest you use the spectre as simulator to simulate switch cap circuit.
Hspice error
Increase the no of points in the .options statement
Added after 19 seconds:
THis will solve your convergence issue
Hspice error
try to give some initial condition
Hspice error
Add .ic or .nodeset can help.
Re: Hspice error
In SC circuits, this kind of error often be appeared in Hspice simulation.
You can add initial condition (.IC) or use large GMINDC (GMINDC>1e-9).
Good luck
Re: Hspice error
try with gshunt and cshunt options
Hspice error
you may use method=gear
Re: Hspice error
you can select .option for help
