didibabawu
Member level 5
Why the circuit in the PIC use more than one serial mos(M1,M2,M3) in linear region whose gate connect together? Why don't use only one transistor in linear region?
3X!
3X!
naalald said:Hi,
The reason is that the calculated size, W and L of the transistor in linear region cannot be implemented by one transistor according to the process and library limitations (minimum/maximum L or W). So they use a series of two or more transistors to implement the desired w and L.
