hilbren
Newbie level 2
Hi everybody, I'am a newbe 8)
I want to make a lap-counter, the only problem is how.
What I do know is that most professional systems work with radio frequencies. Now that’s not a big problem for me, I’ve got a scope and I did build some transmitters. The biggest problem is how to electronically identify every car…
And even a bigger problem: what if two cars pass at the same time ???
At first I was thinking about doing the transmission whit IR; that way I could build a singlechip IR remote control chip. That way I could give each car specific code.
The only problem with IR is that most IR led’s work at a maximum frequency of 56khz, and that’s to slow. And off course the biggest problem, that if two cars pass at the same time.
and then I saw this on atmel.com: http://www.atmel.com/dyn/products/devices.asp?family_id=644#695
A read only chip, but will it be fast enough ?
or are there other options available?
