tjak
Newbie level 2
Vibration motor control
I want to control a small vibration motor from a 5V TTL level. The motor should run on a separate 3.7V supply, which is able to handle the load. (The control signal is either 0 or 5V, never in between but maybe PWM modulated.)
What is the best/easiest way to accomplish this?
Will a standard NPN transistor allow control of a lesser voltage (3.7V) with a higher voltage (5V) signal (and maybe a suitable resistor) or is there an advantage in using another approach (another transistor type perhaps, MOSFET?)?
Help will be appreciated. Thanks.
Thomas
Thomas
