suria3 said:Normally, a Monte Carlo simulation of 1000 runs can convince you about the performance of the designed amplifer which will fall within your design specification.
A.Anand Srinivasan said:suria3 said:Normally, a Monte Carlo simulation of 1000 runs can convince you about the performance of the designed amplifer which will fall within your design specification.
what do u mean by monte carlo simulation of 1000 runs.... Monte carlo needs to be done at the different corners only na.????
A.Anand Srinivasan said:the result of monte carlo is gonna be same at whatever time u run it.... so i just wanted to know why 1000 runs??? what difference is that gonna make...
