most cheap way of communicating the s7-200 with the pc
how built cable s7-200
hii Molehiya
I think you must change your connecting point setting
if you can t change this I will send email "how to change "
s7 200 cable
hii
I can help if you mail to me
I sent circuit a lot of friends
many friends it worked
best regards
pc/ppi cable 11bit setting
I improved this cable
I can send circuit shematic and PCB
best regards
s7 200 port 0 pins diagram
Hello!
For S7-300,S7-400 you need an PC USB adapter or a CP5511/CP5512 adapter.Until now there is no schematics.
For S7-200,S5 try this link:
Best regards!
Venix
Reactions: macir
    macir
diagram for s7-200 pc ppi cable
A good link
Best regards!
problems communicating with s7 222 cpu
@macir:
I received your file but I do not know the software to open file with extention LYT.
PLS show me the name of software to open file
Thanks so much!
pc/ppi cable trouble
You must use " proteus (ARES)" program for this circuit
Best regards!
s7-200 to pc
Best regards!
Thanks so much :idea:
I have drawn a new pcb in Eagle and used 2 port 9 pins :D
Dear jackrs
Please advice me how to test your cable with s7-200 and pc ,give an example with pc software and s7-200 program
Best Regards
MedTronic
Reactions: macir
    macir
Schematic of USB to Logo PLC cable
Tested with Siemens s7-224. Works fine
Download and install drivers from FTDI for FT232B for create virtual serial port
Sorry, the cable usb2logo is not for s7-200
IS FOR SIEMENS LOGO
TESTED WITH LOGO, IT WORKS FINE
Reactions: macir
    macir
thanks for the logo cable. i made it and works fine.
Added after 1 minutes:
hi, again but i need mpi s7-300 cable schematics do you have that?
Reactions: macir
    macir
