+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Full Member level 5
    Points: 3,454, Level: 13
    Join Date
    Sep 2005
    Cebu, Philippines
    Posts
    277
    Points
    3,454
    Level
    13
    rtos design
    Hello Guys,
    Anybody has some documents/links to share how to design preemptive RTOS on PIC18?
    Or are there any Software that supports Preemptive RTOS (similar to Salvo but this case a preemptive RTOS instead of cooperative).
    One high priority task of my applcation (the highest priority task on my applciaiton if running anyway) is to be periodically serviced every 2000 instruction cycles (via a TIMER Interrupt) and the task itself can be serviced in less than 100 instruction cycles. So I will be forced to use preemtive RTOS in teh design since the applcation does a lot of tasks aside from this major high priority task
    Thanks,
    neo
    •   AltAdvertisement
  2. #2
    Member level 4
    Points: 1,484, Level: 8
    firmware's Avatar
    Join Date
    Apr 2007
    Posts
    69
    Points
    1,484
    Level
    8
    rtos design
    Looking at www.freertos.org
    •   AltAdvertisement
  3. #3
    Member level 3
    Points: 1,713, Level: 9
    Join Date
    Nov 2004
    Melbourne Victoria Australia
    Posts
    55
    Points
    1,713
    Level
    9
    rtos deisgn
    you could also try
    http://www.picos18.com/index_us.htm
    which is a partial implementation of OSEK-VDX on a PIC
