Which component we can use to switch on/off an AC power source of 12V ?
microlab
Full Member level 5
dear friends
which component we can use to switch on/off an AC power source of 12V
as we are using triacs for high voltage? can we use optocouplers?
using at89c2051
regards
ml
Re: Ac power on
For 12Vac you can also use a triac ..
For example, the Q2008L4 should work well if you only can "pump" more than 25mA into its gate ..
https://www.datasheetarchive.com/Q2008L4-datasheet.html
It can be driven by an optocopler such as MOC and the gate resistor should be about 20Ω ..
Here are examples:
Regards,
IanP
Ac power on
AC Power source of 12 Volts, relays are enough, optocouplers can do also.
Ac power on
use optcoupler, and AC-AC module
