+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Points: 925, Level: 6
    Join Date
    Nov 2007
    Posts
    Points
    925
    Level
    clock glitch
    Hi all,
    I'm designing clock module for ASIC. This is my first experience in clock module design. For synthesis I'm using Design Compiler. I dont know how to give constraints for generated clocks. Can someone give me some info.
    Also is it posible to check with Design Compiler glithes on generated clocks.
    Or the only way is post synthesis simulation?
    Thank you very much.
    •   AltAdvertisement
  2. #2
    Banned
    Points: 5,691, Level: 17
    Join Date
    Sep 2007
    Posts
    853
    Points
    5,691
    Level
    17
    glitch clock
    Do you mean All digital PLL ?
  3. #3
    Join Date
    Nov 2007
    Posts
    Points
    925
    Level
    glitches on clock
    It more simple then PLL.
    I have 2 asynchronous clock inputs and 5 clock outputs.
    It is just clock divider. It is not dificult module I understand. But it should be glitch free. I already designed the module and its is working with functional simulation.
    But I dont know will it work after synthesis.
    •   AltAdvertisement
  4. #4
    Banned
    Join Date
    Sep 2007
    Posts
    853
    Points
    5,691
    Level
    17
    clock gllitch
    If you are using Asynchrous gates (i.e Muller Gates) the concerned module will nor be synthesized and loops will apear. Else, give more details please.
    Regards,
    Master_PicEngineer
  5. #5
    Join Date
    Nov 2007
    Posts
    Points
    925
    Level
    glitch in the clock
    To be honest I dont know what are Muler Gates :D (if you have some links it will be very appreciated :D)
    I'm using asynchrous gates but there is not any loops.
    It can be be synthesized I tried.
    But I dont know how to check or constraint clock module. How can I be sure that it will work in IC?
    Thanks.
    •   AltAdvertisement
  6. #6
    Banned
    Join Date
    Sep 2007
    Posts
    853
    Points
    5,691
    Level
    17
    how to find glitches
    Joined Constraining designs doc
    Hope it help.
  7. #7
    Banned
    Join Date
    Sep 2007
    Posts
    853
    Points
    5,691
    Level
    17
    glitch in clock
    Additional materials on Asynchronous Circuits Design:
    http://www.mrc.uidaho.edu/mrc/people/jff/540/index.html
