first of all, you should have the model for monte carlo.
then you should replace the circuit with the monte carlo model.
and you can simulate the circuit with the monte carlo model.
from menu “Setup” choose “Model Libraries” change all the option fields so that instead of “tm” you have “mc” (for instance cmostm cmosmc)
You then choose monte carlo from the tools menu and set it up as you wish. Set the expression you want to plot in the calculator and click the 'get expression' button in the monte Carlo window, give it a name and click add. Choose 'run' from the simulation window to run the simulation.
edit: You must also have the simulation you want to run enabled in the analog environment as usual.
