haris_khan
Newbie level 5
fft pic16f
can any one give me fft code in c for PIC16F877
#include <16F877A.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP
#use delay(clock=20000000)
#use rs232(baud=115200, xmit=PIN_C6, rcv=PIN_C7) // Jumpers: 8 to 11, 7 to 12
#include <MATH.h>
#include "header.h"
#include "tables.c"
void main() {
signed int zeroimag = 0;
long int SRAMpos = 0;
long int i, l2, l,l1, j;
char tempchar;
signed int real, imag, real1, imag1;
signed int tempval;
long int i1, t1, t2, u;
long z, h, tempr, tempi;
//signed int i, i1, j, l, l1, l2, t1, t2, u;
setup_port_a( AN0 );
setup_adc( ADC_CLOCK_INTERNAL );
set_adc_channel( 0 );
do {
printf(" \n\r press a to take analog sample \n\r");
do {
tempchar = getc();
} while (tempchar != 'a');
for (i=0; i<256; i++) {
setSRAMaddy(SRAMpos, 0);
real = Read_ADC();
real = (real-128)/4;
writeSRAM(real);
//printf("\n\r---> %d \n\r", real);
setSRAMaddy(SRAMpos, 1);
writeSRAM(zeroimag);
delay_us(2194);
SRAMpos++;
printf("%d ", real);
l2 = 128;
i=0;
for(l=0;l<255;l++) {
if(l < i) {
setSRAMaddy(l, 0);
j = readSRAM();
setSRAMaddy(i, 0);
real1 = readSRAM();
setSRAMaddy(l, 0);
writeSRAM(real1);
setSRAMaddy(i, 0);
writeSRAM(j);
l1 = l2;
while (l1 <= i){
i -= l1;
l1 >>= 1;
i += l1;
/* Compute the FFT */
u = 0;
l2 = 1;
for(l=0;l<8;l++){
l1 = l2;
l2 <<= 1;
for(j=0;j<l1;j++){
for(i=j;i<256;i+=l2){
i1 = i + l1;
setSRAMaddy(i, 0);
real = readSRAM();
setSRAMaddy(i, 1);
imag = readSRAM();
setSRAMaddy(i1, 0);
real1 = readSRAM();
setSRAMaddy(i1, 1);
imag1 = readSRAM();
t1 = (u1[u]*real1 - u2[u]*imag1)/32;
t2 = (u1[u]*imag1 + u2[u]*real1)/32;
setSRAMaddy(i1, 0);
writeSRAM((real-t1));
setSRAMaddy(i1, 1);
writeSRAM((imag-t2));
setSRAMaddy(i, 0);
writeSRAM((real+t1));
setSRAMaddy(i, 1);
writeSRAM((imag+t2));
u++;
for (i=124; i<133; i++){
setSRAMaddy((int8)i, 0);
real = readSRAM();
setSRAMaddy((int8)i, 1);
imag = readSRAM();
//printf("\n\r Value %ld: %d + i%d\n\r", i, real, imag);
/* Find the highest amplitude value */
/* start at index 1 because 0 can hold high values */
j=1;
l=0;
for ( i=1; i<128; i++ ) {
setSRAMaddy(i, 0);
real = readSRAM();
tempr = abs(real*real);
setSRAMaddy(i, 1);
imag = readSRAM();
tempi = abs(imag*imag);
l1 = tempr + tempi;
if (l1 > l) {
j = i;
l = l1;
setSRAMaddy(j, 0);
real = readSRAM();
setSRAMaddy(j, 1);
imag = readSRAM();
tempi = 1.5625*j;
printf("\n\r---> position %ld: %d + i %d value: %ld freq: %ld \n\r", j, real, imag, l1,tempi);
u = 0;
l = 0;
l2 = 0;
l1 = 0;
j = 0;
i1 = 0;
SRAMpos = 0;
t1 = 0;
t2 = 0;
real = 0;
imag = 0;
real1 = 0;
imag1 = 0;
} while (TRUE);
signed int readSRAM(void) {
char temp_char = 0;
int i;
// Delay after seeing that data is available so that the
// data can be written to the SRAM.
//delay_us(4);
// Set the SRAM enables to READ.
//OE = 0;
//WE = 1;
//CS = 0;
output_low(OE_PIN);
output_high(WE_PIN);
//output_low(CS_PIN);
delay_us(1);
// Reads from the SRAM
temp_char = input_d();
delay_us(1);
// Stop READing by setting to IDLE state
//OE = 1;
//WE = 1;
//CS = 0;
output_high(OE_PIN);
return temp_char;
* writeSRAM() *
* Sets the correct enables and clocks the *
* counter to write to SRAM *
void writeSRAM(signed int value) {
int i;
// Set SRAM to WRITE
//chartobin(value);
output_high(OE_PIN); // Enables WRITE
output_low(WE_PIN);
delay_us(1);
//OE = 1;
//WE = 0;
//CS = 0;
output_d(value);
delay_us(1);
// Stop WRITING by setting to IDLE state
//OE = 1;
//WE = 1;
//CS = 1;
//output_high(CS_PIN);
delay_us(1);
// Clear I/O pins
input_d();
delay_us(1);
void setSRAMaddy (unsigned int pos, short img) {
output_b(pos);
if (img) { output_high(PIN_C3); }
else { output_low(PIN_C3); }
delay_us(1);
