merge lots of gds to one file?
calibre
Newbie level 5
merge gds
I check tsmc standard cell library, there are so mang standard cells, but when i stream in the library, there is one file for all cell gds, how do they merge all standard cells gds to one file?
merge gds of all cells
this is the norm thing to do , u make gds to the top cell and the gds will contain all the cells included in that Top cell, so u just need to make a Top Cell and instantiate all the standard cells u need in it then export a gds file of this Top Cell
gds merge
Hi, safwatonline
i find there are no any top cell included these standard cells, so i wander there is a way to merge lots of gds to one gds file?
actually if u r using cadence when u export the stream u can just name the library name and don't enter any cell name then the exported file will contain all the cells inside the named library
if we are using the same gds command. Using the listlib command followed by the gds data then it will display all the instances inside that stream and the first instance to display is the top cell...
Added after 14 minutes:
I agree, this is also the idea i have in my mind. The new cell that you created and instantiated all the standard cells u need when u export it this will become your top cell.
IF your question is merging diffrent gds to one gds only w/o top cell, I dont have any idea of that. Is that really possible...?I hope someone knows......
Teddy said:
http://www.artwork.com/gdsii/gdsfilt/file_merge.htm
GDSII is relativelty easy to understand and is well documented. The best tool to learn about it is Google...
Any free tools :?:
