+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Full Member level 1
    Points: 1,661, Level: 9
    Join Date
    Jul 2007
    Posts
    97
    Points
    1,661
    Level
    9
    differential amplifier to signle ended amplifier
    assume that i have designed a differential amplifier and i have two outputs Vout+ and Vout-. How do I connect Vout+ and Vout- so that the opamp becomes an single ended amplifier? I am trying to use the opamp in an integrator.
    •   AltAdvertisement
  2. #2
    Points: 11,124, Level: 25
    Achievements:
    7 years registered
    safwatonline's Avatar
    Join Date
    Nov 2005
    EGYPT
    Posts
    1,347
    Points
    11,124
    Level
    25
    u can take one of them only or u can use an unbalanced amplifier
    •   AltAdvertisement
  3. #3
    Member level 3
    Points: 1,732, Level: 9
    Join Date
    Jan 2006
    P.R. CHINA
    Posts
    55
    Points
    1,732
    Level
    9
    hi, the differential input and the single output may be adaptive for your application better, if you must use the fully differential opamp, then the second stage must be D2S
    •   AltAdvertisement
  4. #4
    Advanced Member level 5
    Points: 16,636, Level: 31
    Join Date
    Jul 2001
    Oberon
    Posts
    1,897
    Points
    16,636
    Level
    31
    Just use another op-amp as an output buffer configured as a unity gain differential amplifier.
  5. #5
    Member level 5
    Points: 3,477, Level: 13
    Join Date
    Apr 2002
    Posts
    84
    Points
    3,477
    Level
    13
    Re: differential amplifier to signle ended amplifier
    You can sum the two output currents using a current mirror. You can see this in any elementary analog design book.
    •   AltAdvertisement
  6. #6
    Junior Member level 2
    Points: 1,058, Level: 7
    Join Date
    Aug 2007
    Posts
    24
    Points
    1,058
    Level
    7
    Add differential end to single end circuit , may be you can use current mirror
