SWAPI
Newbie level 3
price 74ls154 india
at online tps
www.onlinetps.com
*ItemID* *Item Name* *Category / Subcategory* *Price* [/b]
154 6V, 4.5Ah Rechargeable Battery Power Supply Rs.260.00
109 10 K Resistance network Mics Components Rs.2.00
25 10 MHz Crystals / Crystals Rs.10.00
144 10 Pin Box Header Connectors Rs.8.00
136 100 RPM Motor Motors Rs.175.00
170 1000 ++ Datasheets Collection ۞ Softwares ۞ / Others Rs.100.00
157 1000+ Electronics circuits CD ۞ Softwares ۞ / Others Rs.150.00
23 11.0952 MHz Crystals / Crystals Rs.10.00
29 12 MHz Crystals / Crystals Rs.10.00
145 16 Pin Box Header Connectors Rs.10.00
89 16x1 Character LCD Module Display Modules Rs.140.00
3 16x2 Character LCD Module Display Modules Rs.160.00
90 20 PIN ZIF SOCKET Connectors Rs.60.00
30 24 MHz Crystals / Crystals Rs.25.00
148 2N2222A Metal Transistors Rs.12.00
107 2N3055 Transistors Rs.18.00
149 2N3866 Transistors Rs.45.00
94 2N3904 Transistors Rs.4.00
95 2N3906 Transistors Rs.4.00
31 3.579 Mhz Crystals / Crystals Rs.10.00
165 30 RPM Motor Motors Rs.175.00
27 32.768 kHz Crystals / Crystals Rs.10.00
159 4 Linux DVD Megapack ۞ Softwares ۞ / Linux Rs.250.00
28 4 MHz Crystals / Crystals Rs.10.00
26 4.9152 MHz Crystals / Crystals Rs.12.00
147 40 Pin F SIP Connector Connectors Rs.20.00
146 40 Pin M SIP Connector Connectors Rs.12.00
91 40 PIN ZIF SOCKET Connectors Rs.75.00
140 433Mhz Rx Module Mics Components Rs.210.00
139 433Mhz Tx Module Mics Components Rs.185.00
141 455 Khz Crystals Rs.8.00
110 4k7 Resistance network Mics Components Rs.2.00
64 74LS00 TTL CMOS ICs / 74xx Series Rs.12.00
65 74LS04 TTL CMOS ICs / 74xx Series Rs.12.00
66 74LS05 TTL CMOS ICs / 74xx Series Rs.12.00
67 74LS06 TTL CMOS ICs / 74xx Series Rs.18.00
117 74LS08 TTL CMOS ICs / 74xx Series Rs.20.00
68 74LS11 TTL CMOS ICs / 74xx Series Rs.12.00
82 74LS125 TTL CMOS ICs / 74xx Series Rs.15.00
116 74LS132 TTL CMOS ICs / 74xx Series Rs.25.00
69 74LS14 TTL CMOS ICs / 74xx Series Rs.12.00
77 74LS154 TTL CMOS ICs / 74xx Series Rs.55.00
119 74LS154 TTL CMOS ICs / 74xx Series Rs.55.00
70 74LS21 TTL CMOS ICs / 74xx Series Rs.12.00
78 74LS244 TTL CMOS ICs / 74xx Series Rs.18.00
79 74LS245 TTL CMOS ICs / 74xx Series Rs.20.00
71 74LS27 TTL CMOS ICs / 74xx Series Rs.12.00
72 74LS32 TTL CMOS ICs / 74xx Series Rs.12.00
118 74LS32 TTL CMOS ICs / 74xx Series Rs.12.00
73 74LS47 TTL CMOS ICs / 74xx Series Rs.16.00
74 74LS73 TTL CMOS ICs / 74xx Series Rs.18.00
75 74LS74 TTL CMOS ICs / 74xx Series Rs.12.00
76 74LS86 TTL CMOS ICs / 74xx Series Rs.15.00
120 74LS90 TTL CMOS ICs / 74xx Series Rs.20.00
114 74LS93 TTL CMOS ICs / 74xx Series Rs.20.00
22 8 MHz Crystals / Crystals Rs.10.00
108 8051 Atmel Programmer Programmers / Devlopment Boards Rs.1600.00
103 8085 Microcontrollers/ Micropocessor Rs.110.00
104 8155 Microcontrollers/ Micropocessor Rs.150.00
175 9V Battery Connector Connectors Rs.5.00
13 AT TINY2313 Microcontrollers/ Micropocessor / ATMEL Rs.60.00
15 AT89C2051 Microcontrollers/ Micropocessor / ATMEL Rs.45.00
37 AT89C51 Microcontrollers/ Micropocessor / ATMEL Rs.65.00
16 AT89C52 Microcontrollers/ Micropocessor / ATMEL Rs.68.00
17 AT89S51 Microcontrollers/ Micropocessor / ATMEL Rs.70.00
38 AT89S52 Microcontrollers/ Micropocessor / ATMEL Rs.70.00
14 AT89S8252 Microcontrollers/ Micropocessor / ATMEL Rs.250.00
18 ATMEGA 16 Microcontrollers/ Micropocessor / ATMEL Rs.160.00
20 ATMEGA 32 Microcontrollers/ Micropocessor / ATMEL Rs.220.00
19 ATMEGA 8535 Microcontrollers/ Micropocessor / ATMEL Rs.160.00
93 BC 547 Transistors Rs.2.00
92 BC 548 Transistors Rs.2.00
168 BC 557 Transistors Rs.2.00
169 BC 558 Transistors Rs.2.00
100 BD 139 Transistors Rs.6.00
101 BD 140 Transistors Rs.6.00
152 BF494 Transistors Rs.4.00
161 Blue LED Display Modules Rs.1.75
4 Bread Board GL-12 Utilities Rs.90.00
102 BT 136 SCR Mics Components Rs.10.00
42 CD 4017 TTL CMOS ICs / 4xxx Series Rs.10.00
45 CD 4026 TTL CMOS ICs / 4xxx Series Rs.15.00
47 CD 4028 TTL CMOS ICs / 4xxx Series Rs.12.00
125 CD 4001 TTL CMOS ICs / 4xxx Series Rs.12.00
39 CD 4011 TTL CMOS ICs / 4xxx Series Rs.10.00
40 CD 4013 TTL CMOS ICs / 4xxx Series Rs.10.00
41 CD 4016 TTL CMOS ICs / 4xxx Series Rs.12.00
43 CD 4020 TTL CMOS ICs / 4xxx Series Rs.12.00
44 CD 4023 TTL CMOS ICs / 4xxx Series Rs.12.00
46 CD 4027 TTL CMOS ICs / 4xxx Series Rs.12.00
48 CD 4033 TTL CMOS ICs / 4xxx Series Rs.15.00
49 CD 4046 TTL CMOS ICs / 4xxx Series Rs.12.00
50 CD 4047 TTL CMOS ICs / 4xxx Series Rs.12.00
51 CD 4049 TTL CMOS ICs / 4xxx Series Rs.12.00
52 CD 4050 TTL CMOS ICs / 4xxx Series Rs.12.00
53 CD 4066 TTL CMOS ICs / 4xxx Series Rs.10.00
54 CD 4069 TTL CMOS ICs / 4xxx Series Rs.12.00
55 CD 4072 TTL CMOS ICs / 4xxx Series Rs.12.00
56 CD 4073 TTL CMOS ICs / 4xxx Series Rs.12.00
58 CD 4078 TTL CMOS ICs / 4xxx Series Rs.20.00
124 CD 4081 TTL CMOS ICs / 4xxx Series Rs.15.00
57 CD 4082 TTL CMOS ICs / 4xxx Series Rs.12.00
59 CD 4093 TTL CMOS ICs / 4xxx Series Rs.12.00
60 CD 4099 TTL CMOS ICs / 4xxx Series Rs.15.00
61 CD 4504 TTL CMOS ICs / 4xxx Series Rs.30.00
62 CD 4511 TTL CMOS ICs / 4xxx Series Rs.12.00
63 CD 4514 TTL CMOS ICs / 4xxx Series Rs.40.00
121 CD4007 TTL CMOS ICs / 4xxx Series Rs.12.00
122 CD40106 TTL CMOS ICs / 4xxx Series Rs.15.00
123 CD4029 TTL CMOS ICs / 4xxx Series Rs.15.00
179 Colour CCD Camera Display Modules Rs.750.00
166 Condenser Microphone Mics Components Rs.4.00
135 DB25 Cover Connectors Rs.12.00
134 DB25 Male Connectors Rs.15.00
142 DB9 Connector Connectors Rs.10.00
143 DB9 Cover Connectors Rs.8.00
150 DB9 Right Angle PCB Mount Connectors Rs.22.00
158 DEBIAN 4.0 (ETCH) 3 DVD PACK ۞ Softwares ۞ / Linux Rs.250.00
178 FM Transmitter Programmers / Devlopment Boards Rs.95.00
164 Green LED Display Modules Rs.1.00
132 HT12E Mics ICs Rs.70.00
112 L293D Mics ICs Rs.95.00
7 LDR-12 mm Sensors / Transducers Rs.18.00
8 LDR-5 mm Sensors / Transducers Rs.3.00
115 LF398 Mics ICs Rs.20.00
111 LM 324 Mics ICs Rs.10.00
96 LM 7805 Mics ICs Rs.8.00
98 LM 7812 Mics ICs Rs.8.00
97 LM 78L05 Mics ICs Rs.10.00
88 LM311 Mics ICs Rs.12.00
113 LM339 Mics ICs Rs.15.00
83 LM35 D Sensors / Transducers Rs.65.00
127 LM358 Mics ICs Rs.15.00
126 LM3914 Mics ICs Rs.45.00
133 LM7912 Mics ICs Rs.15.00
80 LT 542 Display Modules Rs.9.00
81 LT 543 Display Modules Rs.9.00
105 MAX 232 Mics ICs Rs.25.00
99 MCT2E OPTO-COUPLER Mics ICs Rs.12.00
106 Microchip Microcontroller (PIC) Programmer Programmers / Devlopment Boards Rs.700.00
171 MT 8870 Mics ICs Rs.48.00
130 Multi-meter Utilities Rs.145.00
87 NE555 Mics ICs Rs.5.00
85 NM93C46 Mics ICs Rs.12.00
86 NM93C56 Mics ICs Rs.20.00
151 Photo Diode Sensors / Transducers Rs.12.00
11 PIC 16F628A Microcontrollers/ Micropocessor / Microchip Rs.95.00
10 PIC 16F72 Microcontrollers/ Micropocessor / Microchip Rs.65.00
9 PIC 16F84A Microcontrollers/ Micropocessor / Microchip Rs.100.00
12 PIC 16F877A Microcontrollers/ Micropocessor / Microchip Rs.210.00
138 PIR Sensor With lance Sensors / Transducers Rs.245.00
176 Power Jack Connectors Rs.4.00
153 Push Button Switch Mics Components Rs.1.50
167 RCA Jack Connectors Rs.6.00
163 Red LED Display Modules Rs.1.00
177 Small Crocodile Clip Connectors Rs.10.00
131 Soldering Iron Utilities Rs.90.00
6 TSOP1738 IR Sensor Sensors / Transducers Rs.20.00
84 ULN 2803 Mics ICs Rs.18.00
5 Ultrasonic Tx-Rx Transducers Sensors / Transducers Rs.295.00
162 White LED Display Modules Rs.2.00
at online tps
www.onlinetps.com
_________________
at online tps
www.onlinetps.com
at online tps
www.onlinetps.com
_________________
