xfpgas
Junior Member level 2
selectmap partial reconfiguration
I have an application that I can implement on a Virtex device by
Partial Run Time Reconfiguration (RTR).
I have a fixed logic Block. And one reconfigurable Logic Block.
Fixed Logic Block is a processing engine (PE). The data for that will be available in the Reconfigurable Logic. I can either use the LUTs as distributed RAM or just use BlockRAM to store my data. My PE will work on the data and when it is finished I will read the output from the PE.
And then, I will load the Reconfigurable block with the new data to be worked on. So all I have to do is change the contents of the LUT/BlockRAM using JBITS and partially reconfigure the Device for the new data to be worked on by the PE. And this is all the device does -- load the Data into the Reconfigurable Logic Block and let the PE(Fixed Logic Block) do the math on it, and this goes on ....
My goal is to eventually make this a scalable appication with a Big Virtex Device with multiple PEs all working on the Data which will be reconfigured using RTR. And finally, develop a platform to have this done over a huge array of FPGAs.
Does anyone know of any work done on this? I would appreciate your comments and suggestions.
1) Can a Virtex device handle this sort of Partial RTR ? Is there a thumb rule regarding how often partial RTR can be done and if this can be done for the life of the device? ( I apologize if this sounds ignorant, I just want to make sure before I spend more time and resources )
TIA
Kode
TIA
Kode
